problem dots without object not eliminateable
  • Thread starter Thread starter il secco
il secco
Hello everyone
I would have a problem with the file that I attach you to dots that I can't aliminate. I only see the dots when I zoom extensively if I approach the dots disappear, I have already tried to purge and audit the dwg but do not disappear, I agree that they disappear only if I go to paste the design (the one that has the lines and white writings) on another dwg creating a block.
I hope you can hear me.
thanks to all
are not selectable texts. Now I didn't investigate the reason for the rush. However, this is the solution:
command selerapid -> object type "text" -> properties "color" -> operator "equal to" -> colour "yellow"
and gates
then repeat the procedure for green color.
and you will have the design without the anomalies of the "puntines" and you will still remain the texts you need.
