problem in closing a solid imported from step in creo2
fabmorse77
Hello everyone, I'm a crack user 2.
I kindly ask if someone can give me a tip to solve the problem below.
I am importing a step format file sent to me by our supplier. It happens that despite being imposed as solid, I create it as a surface with all the consequences of the case including a very annoying (for controls) that during the creation of a section the solid inside is obviously empty. Now my first move was to try to repair the open surfaces by datadoctor. the whole or going to close the openings with the command "repair, close or with limit blend" the final result does not change and despite in theory no longer have open areas the object in question remains a set of surfaces. exited from the datadoctor environment also all the commands of the change menu (solidify, unite etc.) are disabled. I can't understand... I forget some passage or something?
Thank you very much
synthetically you have to arrange all "geometry checks" from within the import date doctor and then check that there are no unilateral edges in the model with the function finds. If you place the model I can look at it to see what problem it has. otherwise I will try to be more precise in the explanation.
thank you mad76, unfortunately I cannot post the model as it is covered by copyright, but as you have advised me I go through the geometry checks to fix the edges that I may have missed. But I ask you what you mean by "one-sided squirrels" and exactly how I have to set the search in the find. Thank you.
in this way you find all the edges that are not combined with two surfaces. Bye!
I tried in all manners... but I didn't reach the result, probably the solid is too complex... I'll get more ideas. Thank you
