problem in creating pdf 3d
  • Thread starter Thread starter Madmax
Madmax
Good morning to all,
I pose a problem that I have never managed to solve inherent in the conversion in pdf3d that pro-e wf4 generates.
In particular, my doubt lies in the positioning of the rotation center of any model that I realize, when I activate the rotation, the piece does not rotate around itself but around a distant point that makes me disappear from the screen.
Any solutions? I could also pass the pdf or the model... .
thanks in advance
max max
in the past I used pdf3d, but it never thrilled me both as quality and as ease of use. when I have to spin projects only to display I prefer to use edrawing, it is simple to use, generates a fairly small file and the basic version is free.
uses the command "the property of the frame " (the command with the camera)
then tick "starting at destination"
then select "select face"
and finally, select a face, and you will see that the ripple is right
claudio tsolakis
ops:
see now, do not refer to pdf3d, excuse
try so; open the pdf there are various commands to move the model; automatically there is rotation; try to select rotation around the axis, then let us know
