problem in defining part body as work object
  • Thread starter Thread starter Kekko999
Kekko999
Good evening to all,
My name is Franciscan and I am a student of the aerospace engineering course.
using airfoiltools I reported on catia a naca profile 0012, passing from the generative shape design environment to the part design to create the prism of the wing, I can not define in the part body the spline of the shape, practically disappears everything. Can you tell me what the problem is? Thank you.Immagine.webp
Maybe it happens because you are active on the geometric group: you have to activate the body,
then if the spline is not closed by another mistake.. .
no the spline is always open by reporting the points from the site airfoil tools, then I closed it by extrapolation. However after defining the spline, I take myself back to part design to use the prisma command and the allert appears where you have to define the work body (which I created if you look from the tree to the left in the photo above) not recognizing the curve.
If I click right on the part body to define it as an object of work, the spline disappears is this the problem. I don't think he can recognize her.
probably you have selected the icon that allows you to display only the active geometric group (it is the one below that resembles stacked books)
