morte
Good morning to all
I'm going crazy behind autocad as I need to move an object to a ucs that isn't global, so I change from global the ucts to the desired position, and when finally I try to rotate it automatically re-enters the global one
I attach the file if someone wanted to take a look at it given my inappropriate probabilmetne language
View attachment rilievo disegno2.dwgI have to create a bull x a column (to do again), the process would create an arch and then extrude it with direction around the circle and create so the bull, but I can't create the arc in the desired position
thanks in advance :smile:
