problem installation revit 2015
Mejda
Hello, everyone!
I recently purchased a pc and tried to install revit 2015 from the autodesk, the student version that lasts 3 years, but at some point the installation crashes and displays the screen I attached.
I found in the file readme the components of microsoft visual c ++ for which the installation did not go to good end, I uninstalled them and installed the program again, but the result does not change. as operating system I have windows 8.1. Can someone help me solve this problem? ?
I also attach the readme file to the points where there are errors.
2015/6/24:02:14:07 francesca pc-fra install autodesk® revit® 2015 succeed
2015/6/24:02:14:08 francesca pc-fra download play rvt2015_en-it http://edutrial.autodesk.com/swdldnet4/2015/rvt/wi/{ce2e6fc5-94e1-436d-825d-5455d67ae0ea}/rvt2015_x64_en-it-tar.lzma2
2015/6/24:02:14:20 francesca pc-fra download aborted rvt2015_it-it http://edutrial.autodesk.com/swdldnet4/2015/rvt/wi/{ce2e6fc5-94e1-436d-825d-5455d67ae0ea}/rvt2015_x64_en-it-tar.lzma2
2015/6/24:02:14:20 francesca pc-fra install language pack autodesk® revit® 2015 failed download failed, installation aborted, result=1603
2015/6/24:02:20:29 francesca pc-fra rollback autodesk® revit® 2015 succeed
2015/6/24:02:22:05 francesca pc-fra rollback autodesk® revit® content libraries 2015 succeed
2015/6/24:02:22:12 francesca pc-fra rollback Farosdk succeed
2015/6/24:02:22:13 francesca pc-fra rollback microsoft visual c+++ 2005 sp1 redistributable atl security update (x64) failed installation aborted, result=1619
2015/6/24:02:22:13 francesca pc-fra rollback microsoft visual c+++ 2005 sp1 redistributable atl security update (x86) failed installation aborted, result=1619
2015/6/24:02:22:54 francesca pc-fra rollback microsoft visual c+++ 2012 redistributable (x64) failed installation aborted, result=1619
2015/6/24:02:22:54 francesca pc-fra rollback microsoft visual c+++ 2012 redistributable (x86) failed installation aborted, result=1619
2015/6/24:02:22:54 francesca pc-fra rollback microsoft visual c+++ 2005 redistributable (x64) failed installation aborted, result=1619
2015/6/24:02:22:55 francesca pc-fra rollback microsoft visual c+++ 2005 redistributable (x86) failed installation aborted, result=1619
2015/6/24:02:46:17 francesca pc-fra download aborted rvt2015_it-it http://edutrial.autodesk.com/swdldnet4/2015/rvt/wi/{ce2e6fc5-94e1-436d-825d-5455d67ae0ea}/rvt2015_x64_en-it.tar.lzma2
2015/6/24:02:46:17 francesca pc-fra install language pack autodesk® revit® 2015 failed download failed, installation aborted, result=1603
2015/6/24:02:54:39 francesca pc-fra rollback microsoft visual c+++ 2012 redistributable (x64) failed installation aborted, result=1619
2015/6/24:02:54:40 francesca pc-fra rollback microsoft visual c+++ 2012 redistributable (x86) failed installation aborted, result=1619
2015/6/24:02:54:40 francesca pc-fra rollback microsoft visual c+++ 2005 redistributable (x86) failed installation aborted, result=1619
2015/6/24:03:26:41 francesca pc-fra install language pack autodesk® revit® 2015 failed download failed, installation aborted, result=1603
2015/6/24:03:35:13 francesca pc-fra rollback microsoft visual c+++ 2012 redistributable (x64) failed installation aborted, result=1619
2015/6/24:03:35:13 francesca pc-fra rollback microsoft visual c+++ 2012 redistributable (x86) failed installation aborted, result=1619
2015/6/25:15:56:32 francesca pc-fra download play rvt2015_en-it http://edutrial.autodesk.com/swdldnet4/2015/rvt/wi/{ce2e6fc5-94e1-436d-825d-5455d67ae0ea}/rvt2015_x64_en-it-tar.lzma2
2015/6/25:15:56:49 francesca pc-fra download aborted rvt2015_it-it http://edutrial.autodesk.com/swdldnet4/2015/rvt/wi/{ce2e6fc5-94e1-436d-825d-5455d67ae0ea}/rvt2015_x64_en-it-tar.lzma2
2015/6/25:15:56:49 francesca pc-fra install language pack autodesk® revit® 2015 failed download failed, installation aborted, result=1603
2015/6/25:16:04:19 francesca pc-fra rollback microsoft visual c+++ 2012 redistributable (x64) failed installation aborted, result=1619
2015/6/25:16:04:19 francesca pc-fra rollback microsoft visual c+++ 2012 redistributable (x86) failed installation aborted, result=1619
2015/6/25:17:07:33 francesca pc-fra path_length: 155
2015/6/25:17:07:33 francesca pc-fra current directory c:\users\france~1\appdata\local\temp\_ai6db7.tmp
_
2015/6/25:17:29:48 francesca pc-fra download aborted rvt2015_it-it http://edutrial.autodesk.com/swdldnet4/2015/rvt/wi/{ce2e6fc5-94e1-436d-825d-5455d67ae0ea}/rvt2015_x64_en-it.tar.lzma2
2015/6/25:17:29:48 francesca pc-fra install language pack autodesk® revit® 2015 failed download failed, installation aborted, result=1603
2015/6/25:17:33:46 francesca pc-fra rollback microsoft visual c+++ 2005 sp1 redistributable atl security update (x64) failed installation aborted, result=1619
2015/6/25:17:33:46 francesca pc-fra rollback microsoft visual c+++ 2005 sp1 redistributable atl security update (x86) failed installation aborted, result=1619
2015/6/25:17:34:14 francesca pc-fra rollback microsoft visual c+++ 2012 redistributable (x64) failed installation aborted, result=1619
2015/6/25:17:34:14 francesca pc-fra rollback microsoft visual c+++ 2012 redistributable (x86) failed installation aborted, result=1619
2015/6/25:17:34:14 francesca pc-fra rollback microsoft visual c+++ 2005 redistributable (x64) failed installation aborted, result=1619
2015/6/25:17:34:14 francesca pc-fra rollback microsoft visual c+++ 2005 redistributable (x86) failed installation aborted, result=1619
2015/6/25:17:41:45 francesca pc-fra is currently running another installation or autodesk update. wait for the completion of the operation, then click on retry.2015/6/25:17:41:49 francesca pc-fra is currently running another installation or autodesk update. wait for the completion of the operation, then click on retry.2015/6/25:17:41:49 francesca pc-fra === setup ended ===
2015/6/30:12:59:21 francesca pc-fra rollback microsoft visual c+++ 2005 sp1 redistributable atl security update (x64) failed installation aborted, result=1619
2015/6/30:12:59:21 francesca pc-fra rollback microsoft visual c+++ 2005 sp1 redistributable atl security update (x86) failed installation aborted, result=1619
2015/6/30:12:59:48 francesca pc-fra rollback microsoft visual c+++ 2012 redistributable (x64) failed installation aborted, result=1619
2015/6/30:12:59:48 francesca pc-fra rollback microsoft visual c+++ 2012 redistributable (x86) failed installation aborted, result=1619
you don't have to uninstall them. try installing them manually ( download them from the microsoft site) and then start revit installation.
thanks to the answer tristan, I have also done so but I have not yet solved:(
So you only solved what you said earlier?
but I think the problem is not in the vcredist but here"2015/6/25:17:29:48 francesque pc-fradownload abortedrvt2015_it http://edutrial.autodesk.com/swdldnet4/2015/rvt/wi/{ce2e6fc5-94e1-436d-825d-5455d67ae0ea}/rvt2015_x64_en-it-tar.lzma2
2015/6/25:17:29:48 francesca pc-fra install language pack autodesk® revit® 2015 faileddownload failed, installation aborted, result = 1603 "
edit: try to download it from herehttp://efulfillment.autodesk.com/sw...381_e616061a11f2990856c4d8e3f2148d6a&ext=.exe
