problem listed where the final message and the "princ" of the counter is not displayed
Angelo2449
Hello everyone,
I wrote this program that traces polar vectors, it works fine but, I do not understand why the final message and the "princ" of the counter is not displayed.
Code:
 (setq fc3 (findfile "c:\\\\autocadsupporto\\polar\\multipolar.dat"))
(if fc)
(vl-file-delete "c:\\autocadsupport\\polar\multipolar.dat")
(setq fc3 (findfile "c:\\\\autocadsupporto\\polar\\\polar.dat"))
(if fc)
(vl-file-delete "c:\\\autocadsupport\\polar\\polar\polar.dat")
(setq cont 0)
(setq nomex1 nil)
(setq nomex2 nil)
(Sectq and 1 nil)
(setq title1 (strcat "selects the station name: " (itoa cont)))
(while (= ed1 nil)
(princ title)
(Sectq ed1 (entsel))
(setq list1 (entget (car e1) '("group")))
(setq xlist1 (assoc -3 list1))
(setq txtdata1 (car (cdr xlist1))
(setq ed1 (entget (car ed1)))
(setq txt1 (cdr 1 ed1))
(setq en1 (cdr -1 ed1))
(setq point1 (cdr 10 ed1))
(redraw en1 3)
(setq nomex1 (nth 1 txtdata1))
(setq type-point1 (cdr 2 txtdata1))
(setq quota1 (cdr (nth 3 txtdata1)))
(setq ecef1 (nth 4 txtdata1))
(setq gaussboaga1 (cdr 5 txtdata1))
(setq controllerstz1 (nth 6 txtdata1))
(setq controlpt1 (cdr 7 txtdata1))
(if (and (= checkpt1 "not defined") (= checkstz1 "not included"))
(progn)
(alert "unsuccessful selection")
(exit)
(Sectq ed2 nil)
(setq title2 (strcat " selects the name of the orientation point : " (itoa cont))))
(while (= ed2 nil)
(princ title)
(setq ed2 (entsel)
(setq list2 (entget (car ed2) (group))))
(setq xlist2 (assoc -3 list2))
(setq txtdata2 (car (cdr xlist2))
(setq ed2 (entget (car ed2))
(setq txt2 (cdr 1 ed2))
(setq en2 (cdr -1 ed2))
(setq point2 (cdr 10 ed2))
(redraw en 23)
(setq nomex2 (nth 1 txtdata2))
(setq type-point2 (cdr 2 txtdata2))
(setq quota2 (cdr (nth 3 txtdata2))
(setq ecef2 (cdr 4 txtdata2))
(setq gaussboaga2 (cdr 5 txtdata2))
(setq controllerstz2 (nth 6 txtdata2))
(setq controllerpt2 (cdr 7 txtdata2))
(if (and (= checkpt2 "not defined") (= checkstz2 "not included"))
(progn)
(exit)
(while)
(setq fp1 (open "c:\\\autocadsupport\\polar\mt.dat" "w"))
(write-line namex1 fp1)
(write-line namex2 fp1)
(close fp)
(redraw en1 4)
(redraw en2 4)
(princ "\n")
(princ "gaussboaga1 > > > > > > > > )
(princ gaussboaga)
(princ "\n")
(princ "gaussboaga2 >>> > > > > > > > > > > > > )
(princ gaussboaga)
(princ "\n")
(setq posvirg (vl-string-search "," gaussboaga1))
(princ "\n")
(princ "posvirg > > > > > > > > > > )
(princ posvirg)
(princ "\n")
(setq cx1 (substr gaussboaga1 1 (- posvirg 1)))
(setq cy1 (substr gaussboaga1 (+ posvirg 2))
(setq point1 (list (atof cx1) (atof cy1))
(setq posvirg (vl-string-search "," gaussboaga2))
(princ "\n")
(princ posvirg)
(princ "\n")
(setq cx2 (substr gaussboaga2 1 (- posvirg 1)))
(setq cy2 (substr gaussboaga2 (+ posvirg 2))
(setq point2 (tof cx2) (atof cy2))
(setq organg (angle point1 point2)
(command "_line" gaussboaga1 gaussboaga2")
(command "_change" "_last" "_p" "_c" "_red"")
(seq origin t)
(startapp "c:\autocadsupporto\\\liberty\\mt3.exe "c:\\autocadsupport\\\\liberty\\mt3.tkn")
(seq control1 nil)
(while (= control1 nil)
(setq control1 (findfile "c:\\\autocadsupport\\polar\\\polar.dat"))
(princ "\n")
(princ "control1 > > > > > > > )
(princ control)
(princ "\n")
(seq control2 nil)
(while (= control2 nil)
(setq control2 (findfile "c:\\\autocadsupport\\polar\\\polarsetup.dat"))
(setq hprisma nil)
(while (= hprisma nil)
(if (= control2 "c:\\autocadsupport\\\polar\\polarsetup.dat")
(progn)
(setq fp2 (open "c:\\\autocadsupport\\\polar\\polarsetup.dat" "r"))
(setq vectors (read-line fp2))
(setq circle (read-line fp2))
(setq radius (read-line fp2))
(setq increase (read-line fp2))
(setq colorline (read-line fp2))
(setq colour circle (read-line fp2))
(setq fine (read-line fp2))
(setq libretto (read-line fp2))
(setq notation (read-line fp2))
(setq note orientation (read-line fp2))
(setq hstrument (read-line fp2))
(setq hprisma (read-line fp2))
(close fp)
(setq fp10 (open "c:\\\autocadsupport\\\\librettopregeo.dat" "a"))
(if (= control1 "c:\\\autocadsupport\\\polar\\polar\dat")
(progn)
(setq fp1 (open "c:\\\\autocadsupporto\\polar\\polar.dat" "r"))
(setq numrighe (read-line fp1))
(setq station (read-line fp1))
(repeat)
(setq i (+ i 1))
(setq line (read-line fp1))
(setq dincl (substr row 18 14)
(setq distincl (atof dincl))
(setq angath (substr row 37 19)
(setq angzenith (atof angath)
(setq angzenith (abs(- 100 angzenith)))
(setq angzenithrad (* (/ angzenith 400) pi))
(setq coszr (cos angzenithrad)
(seq distancers)
(sin angzenithrad)
(Sect of difference in level (* sinezr))
(setq quotax (- (tof quota1) difference in altitude)
(setq quotastr (rtos quotax)
(setq angah (substr row 62 20)
(setq angazimuth (atof angah))
(setq ag1 (angle point1 point2)
(setq agrad (/ angazimuth 200)
(setq agrad (* agrad pi)
(seq point (polar point1 (- (* 2 pi) (- agrad ag1)) distancers)
(setq description (substr line 92)
(setq description (vl-string-trim " description)
(if (= carriers "1")
(progn)
(command "_line" point1 ")
(if = circle "1")
(progn)
(command "_circle" radius point)
(setq point name (substr row 1 14)
(setq posblank (vl-string-search " point name))
(setq point name (substr point name (+ posblank 2))
(setq point name (vl-string-trim " point name))
(command "_text" point 0.40 0 point name)
(command "_change" "_last" "_p" "_c" 174 ")
(if (= booklet "1")
(progn)
(setq naming (entlast))
(seq object "group")
(if (not (tblsearch "appid" object)
(regapp object)
(setq oldlist (entget nomeentita)
(setq xyz (cdr 10 oldlist))
(setq gaussboaga (strcat (rtos (car xyz)) "," (rtos (cadr xyz))))
(setq thedata (list -3 (cons 1000 point name) (cons 1000 "basic final page") (cons 1000 quotestr) (cons 1000 "---------------") (cons 1000 gaussboaga) (cons 1000 nomex1) (cons 1000 "definite")))))
(setq newlist)
(entmod newlist)
(princ "\n")
(princ "i > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
(princ i)
(princ "\n")
(close fp)
(close fp10) ;
(alert "polar tracing performed")
I repeat, apart from the two details, the code works great! ! !
p.s. I have deleted the declaration of variables for reasons of space.
