problem migration autocad 2004
  • Thread starter Thread starter Attila29041981
Attila29041981
We draw with inv 2010 but for customers we have to convert the files to autocad, often 2000 or 2004.
Try to make a safe copy with the name in dwg 2004, and then open it with mech 2010, I can't quote because the share disappears (power quota control and linear quota ).
Thank you in advance.
a greeting to all
a greeting to all
hi, I often have to disconnect the 3d with autocad....however I tried to save a design(I normally carry it in autocad2007), but I set it in autocad 2004, but the quotation power works me equally. of course, before save by name From the idw, you went into the rescue options, didn't you? Have you ever tried to put any share in inventor, and then copy, if the attributes of that quota in autocad?
I used the options
-autocad 2004
-no pack and go and dwg customized
- I gave him the dwt model.
- scale sheet/space model
- nearest autocad map
I took a drawing already complete of quotas
found the problem. .
savevoil 2004 but as a model autocad I gave a dwt in version 2010. .
He's a little angry.
