fabrizio UC21
Hello everyone, I have a problem with acad 3d 2010 and I'm going crazy!
I have to draw a surface made up of polygonal mesh (a hyperboloid) generated by the revolution of a straight skew compared to another. I tried in every way, but I don't know why, with any command the software does not recognize the surface as such. if for example use (very simple method) subtract, and subraggo to the surface a solid, acad responds "no solids, surfaces, or regions selected".
even if I try to insert a section plan along the surface, the plan does not work! specific that the surface has been created with revsurf (mesh per revolution), while if I realize any surface with the classical command "revolves" then it is possible to draw, subtract etc. but hyperboloid can not create it like that!
Thank you in advance.
