problem non circular holes
  • Thread starter Thread starter Dario22
Dario22
Hello everyone,
both drawing a circle and then extruding using the 'task' command that using the hole command on the 3d model, hexagonal holes are practiced. I thought it was a matter of "resolution" of the display, but printing the model in 3d actually the holes are hexagonal.
Is there any setting that's giving me this kind of problem?
How to solve?
thanks to all
First, put the resolution in place:
menu/instruments/options/general/view/performance/precision in 3d/fix (set 0.01)
if the 3d you got it exporting to stl, that format is influenced by resolution graphics.
export the 3d again
Let me know.
years ago
Hi, gianni,
I had already seen the setting you're talking about, but I didn't think the display resolution would affect the output file, but you were resolute, thank you.
By modifying the resolution, importing the stl file into slic3r, they finally result in beautiful circular holes.
Thanks again for the help.
a greeting
Dario
Good evening,
I have a problem with catia v5 64 bit, when amounting a step file, cartpart, or product I cannot view all parts. this only does it on my pc that has a graphics card gtx1650 nvidia. sure of an answer greetings frank
try to change the drivers of the graphics card by putting those specific certificates of catia, or to the limit those of nvidia
If you ask this question you probably don't have much familiarity with the operating system, so I suggest you help as you could combine trouble.. .
However on the internet go to the site nvidia and you look for support - download the latest drivers, set the data card and operating system etc. and download the driver that you autoinstall
always on the nvidia site you can search for dassault certified drivers, but the gtx I think is more for the games, it would take a picture.
at your own risk.. .
hello thanks first of all of the support, but don't you think they're cat settings?, why initially I could read the files
but I'm sorry, instead of specifying the graphics card, why didn't you say it before?
you may have touched some parameters, which I know filter layer or type of display specific well what you do not see when you open a part, just as when you open a product, and igs: do not see some surfaces, what is missing?
at the limit you can delete casetting to return to the beginning of the installation. . .
but does the tree have content?
the file is opened regularly without giving errors?
Do you do it with all the files?
in the tree part c e? but it doesn't appear on video. you with more than one step file
we try with filters:
menu tools display filters all visible filters
Then try
menu displays geometry (must have a check mark)
Let me know.
if you have no particular settings, try to delete catsetting (to find them look for on the forum the procedure is described), then reboot.
Let me know.
thank you so much for everything ..... anyway thanks to you I managed to solve the problem...where I was simple to restore the default settings....and select the licenses... Thank you very much
