problem of representation of retinals away from origin
jim78b
Hello I have a problem with alternative nets, let's say that if I do the retino on a new file all ok, if I do it on the cards on which I'm working it all makes me staggered it is as if I do not curve the lines in short in the image that place the broken lines should be u!
It's normal when you're dealing with restraints far from origin. gb maps have the origin of millions of units away and this is a side effect. moves the origin of the detachment near the field area or moves the bird near the paper, then regenerates. You'll see how it works.
you have the origin of the bird too far, if you can't move the card temporarily moves the origin in its proximity.
440.webpOops... I delayed to realize the image, replay of the response of tristan. :tongue:
Thanks then it worked!!!
Another problem with the line, I would have a geological style line is what: more or less!
_
line with triangle in the center, except if I want to represent it with a larger scale the triangle disappears....
