problem of "sharing violence"
  • Thread starter Thread starter Fulvio G
Fulvio G
I do not use revit daily and therefore I am not sure that it is due to the new update of windows 10, but since a dozen days ago windows (I have a computer asus i7, windows 10 home, 64 bit) has made an update so consistent to keep occupied the computer for almost an hour, I can no longer work with revit: every time I carry out a rescue or for example modifiable of families continue to have error of “sharing” I have remedied until now by copying all the content into a new file and renameing the job, but I only get to be able to save the changes, but then the problem is resumed and especially this does not always work. I’m working with the 2015 version I tried to uninstall it, erasing all files and installing everything again, but the problem didn’t work out.
I found this problem only with revit.
Has anyone else happened? Can someone give me advice on how to solve this damn problem?
I don't think this is the problem but to be lazy in the minimum requirements of revit 2015 there is no windows 10.
update is win10's "anniversary update".
I would recommend that you uninstall the prg using a prg for example as a revo uninstaller and then reinstall the whole.
Good luck!
