problem on toothed wheel in a set
  • Thread starter Thread starter fedemito
fedemito
hello to all I take the opportunity to write after a long period of non-activity, to undergo a problem that happens to me with solidworks 2011.
I have a set composed of various parts + a toothed wheel.
the toothed wheel was created with the automatic creation tool of the sw profile. after generating the profile I modified the wheel with different functions, for example by creating a hub.
the problem arises when I open the file together.
sw in the axieme opens the toothed wheel without the successful changes I have made (in practice the hub does not appear and all the other features that make it)
the 3d originally was created with sw 2010 and never gave problems; just installed sw 2011 came out this magagna. .
Does anyone have any idea how to do this?
thanks to all in advance:smile:
Faithful
Faithful
If you do a research we've already talked about. on the fact that the hub must be done with the toolboxes, inserted in a set and cut, modified etc., otherwise delete all configurations of the renamed component and create a new (configuration).
Thank you, I've been looking, but I haven't found anything to do with my case, I'll look better!
