fantaste
good morning to all, I imported a .stl file from ansys using a process found in the network (from assembly, inserted with existing component, displaced with dmu optimizer and saved as a model, finally copied and pasted the model in part design). Unfortunately, when I start working on the surface that I would like to process the computer becomes very slow and catia starts to "not respond", even if I delete the surfaces that I don't need and use only one. the file doesn't seem very big, let's talk about 4mb... do you have any advice to give me to solve this problem? Thank you in advance for any answers.
steak
steak
