problem project geometers
  • Thread starter Thread starter dicifa
dicifa
hello to everyone, it's been a couple of months that I have a problem:
I'm working in a large set made up of other sub-assistances and I happen to project geometries to make holes (it's always done without any problem) but lately I happen that when I do the extrusion on projected geometries, the constraints start to go crazy.....to someone happened?
But, honestly, no, try to do this: if the projection you need in one part within a subaxieme, open the latter and do it in the window of this (in this way the adactivity is linked to the context of this together and not the largest).
or, try to make a non-adaptive projection of the edge (hold ctrl while selecting) and see what it does.
if you use adaptive projections, sooner or later you'll find yourself with problems, even the kind you mention.
the projection of reference geometries is comfortable just to have a reference, after which I remove it and put the quotas in the specific sketch of the piece affected by the processing.
Bye.
Thanks diegus, I didn't know you could do so!!! so I have the opportunity to project geometry and not make it adaptive.
Bye.
You're right. It's convenient, but it's gonna give you some trouble. I tried to make ome says diegus and I found myself great.
