problem raised
  • Thread starter Thread starter revit86
revit86
I have a problem in rendering the windows with the shields in the base library of revit.
the inner lines of the shields do not appear in the rendering, but appears as a single piece.
Can you help me?
I had the same problem, if you mean inside the so-called "spadarelle" or frangisole interposed in the frame of the dark; the reason I think is that the render refers to the type of aspect assigned to the material where an image with swordsmen and crack between one and the other does not exist. I had built a dark one with swordsmen as 3d elements inserted in the dark; but every time you change the size you need to change the family.
