problem render decalcomanie
  • Thread starter Thread starter dakky
dakky
I press that I tried to look for black decals and nothing came out, but I and the forums are known that we have problems:tongue:
Anyway I stick the decal on a wall and then when I go to make the render it turns out black and tells me that it does not find the file... And yet it is there, what can it be? ?
I reported the adsk support several months ago in October. the answer was: "We know." But I'm afraid he hasn't been settled yet. as workaround tries to change format to the image.
I'm sorry for the ignorant profane question, but what happens if you walk away 1 cm. The image from the wall, so what doesn't lie on the wall?
I don't even know why I'm profane, but I don't think a decal can be moved by the host.
However I try to change from jpg to other veduma:) thank you
to me however it seems that a chincinino she is moved from the wall of her
I had problems with the decals once, and I was nailed to make
When I found out it was the decal I took it off and everything went smoothly
then put it back and gave me no trouble
Boh!
I lost in my... desecration.
question: you could in revit save a view wireframe, then a rendering, and finally a photo montage with a graphic editing program?
I mean, something like this:
render in wire no because there are no solids and faces to render
view the mold as pdf or other bitmap printer you have installed
and then the amounts in the chart program
I do it for the seedlings furnished in 2d, but nothing takes that you can do it also in 3d
