problem rendering 3dface
alb.to
Good morning to all,
I have searched in your forum this issue that frequently resumes me, but I have not found any solution.
importing from autocad a dwg in 3d studio, known that during the process of rendering, some 3d faces, created with the command "3dface", disappear. while in the preview, everything seems to appear to perfection, in the renders you lose numerous objects, in this way.
I tried to bring the drawing to the center of the origin of the axes, to appear weld nearby vertices putting a minimum value of weld threshold (0,001) e maximum surface deviation for 3d solid (0,001), I tried to tick even orient normal of adjacent faces consinstely, but nothing, they keep disappearing.
Does anyone know how I could solve this?
Thank you so much in advance!
definitely is a problem of normal. I realized that in order to always have the normal positives you have to draw the 3d faces anticlockwise.
anyway in 3d studio there is the standard flip command, which allows you to overthrow the normal
