problem renders for base of solid object
  • Thread starter Thread starter R_Nash
R_Nash
hello to all
I would have a problem with autocad 2011, when I make the render, once the calculation of indirect light is finished, the program interrupts the operation by writing to me that it is not possible to render for lack of solid object in the scene.
noriesco understand why the object is present in the view
what I have noticed is that in the iconetta exactly under there processing of the rendering that represents a teapot is also present the symbol of the x
I would like to inform you that with the same programme I have made other positive results.
I checked the settings and between the current one and the previous renderings there is no difference
with autocad 2009 and 2007 no problem.
pc 2,8 gh quad, 6 giga ram 1333, ge maybe 230 1.5 gb memory
the correct phrase of the error and I take the following
impossible to render the scene, the scene must contain at least a 3d wire object or a solid to be submitted to make
cordial greetings to all
hi, sorry if I didn't answer but I wasn't in place and I didn't have the chance to view the forum. the answer is yes, it is absolute a solid but the result is equal semore. are right in the high sea
with autocad 2009 and 2010, same file, no problem.
If I don't come over, I'll use one of the previous two, but I don't deny it makes me mad.
thank you very much anyway and excuse me for the titardo
I have no way to test 2011 however do you do some checks i.e. open new files and insert solids of different shapes and sizes, activate and turn off g.i. and for each situation launch a low resolution rendering, then let us know
I have tried to make to multiple resolutions is I have seen this result
640x480, presentation, active advanced lighting, everything ok
1024x768, presentation, advanced lighting active, everything ok
when instead I change the resolution, type 3264 x 2448 the render stops and in the window you see the render done before but with the name of the current rendering I had put to do.
return to resolutions from 2048 x 1536 and everything is ok.
mystery
with the other cad no problem at any resolution.
It is an astonishing thing because in 2011 I have to do the update that in addition to everything costs me 700 euros without coming up with this thing
the advanced lighting ( final gatering) I kept it active because everything seems to depend on the resolution.
Help.
the 2^ and the 3^ option are equal however, if it is the resolution perhaps it can depend on the graphics card ge perhaps 230. you should check compatibility on the autodesk site
I try to inform myself, but I don't think it's a compatibility problem. Anyway, I'll be right up and then I'll let you know
Thank you very much
