kasak985
Hi...:redface:
I am carrying out a modal analysis on a fairly complex structure with many bodies.. .
after various analysis, carried out with mesh of different relevance, I constantly got on 10 ways to vibrate well 6 at zero hz frequency and the other 4 ways at low frequencies. in the order of 0.01.
to better investigate the cause of the problem I checked the deformation for each of these ways of vibrating. had these zero-frequency results hz referenced bars full thickness 5mm that Sembravano esplodere!. : their deformation is about tens of meters if not more and from the graphic window it seemed just an explosion... .I would definitely say that the result is unreliable and I think these bars have some problems.. .or there is a problem of setting the analysis that I miss or ignore... .
the material is ok as well as contacts... .
the same problem that I am describing to you earlier also in a structural analysis on another structure always with many bodies, even when looking at the deformations, square-sectioned bars seemed to liquefy...while the rest of the structure remained integral essential... .
this problem was arranged barbariously eliminated by the cad these components....
in summary: have you ever seen among the results bodies that have huge deformations, orders of magnitude greater than the rest of the structure?? ? I mean bodies that seem to deform completely unreasonable? ?I'm sure with experience you can help me.. . .grazieeeeeeeeeeeeeeee e buon weekend a tutti:redface:
ps: thank you for the hand you are giving me... I promise that Grandma will collect the necessary experience I will make available to all users of the forum....:redface:
