problem scala pdf when zoom
Max_75it
file pdf submitted, autocad
Good morning, did anyone find this problem?
finding a solution?
thanks and good day.
max max
the scale of an imported pdf file changes when zooming in autocad
autodesk support
9 May 2022
problema:​
the scale of an imported pdf file changes when zooming in autodesk autocad.
solution:​
the following elements can be useful:
  • import pdf as an ole object
  • if this operation is not enough or has already been imported as an ole, it could be caused by a conflict with adobe acrobat reader 11 -> install acrobat reader 9
Moreover, the change of scale does not happen with all pdf.
sometimes, downloading again the same pdf from the same site the problem does not turn out.
I don't think it depends on pdf, the file is the same reloading it the second or third time it goes in place.
but it is a waste of time, the file is a catastral e.d.m. that should be oriented, scaled, etc.
for example on microstation stations, this problem never happens.
