problem sp04
  • Thread starter Thread starter teseo
Hello everyone
a question someone went to 2015sp04?
I would like to know from you if you have any reconventions other than mine? ?
continuous crash loading errors dll gdt analysis support.dll upload errors dwg library....ecc
to me it worked this procedure to solve the same problem:
1: click on start / all programs / accesses and select command prompt
2: Right-click and choose to do as a trainer
3: Once the prompt is opened, type "cd c:\program files\solidworks corp\solidworks" (to be sent)
4: type "sldworks.exe /regserver" (message)
5: Try to open solid, the problem should be solved.
I hope I've been helpful and let you know how it went.
Unfortunately I only see now....
from despair I passed to the pr01 2016 for now better sure than 2015sp04....
Hello everyone
Hey, did you solve this? I went to windows 10, clean installation, I went to solidworks 2015 sp.04, clean installation and from also to me the error "gdt analysis support.dll"...how do I solve it?
I solved it I passed to 2016 :cool: hello
2015 for me is to forget.... .
quiet also 2016 do not joke today I saw an update sp0.1 nice no we start well.... .
I would tell you to wait a bit in the hope that 2016 will become something better; It is clear that 2015 at least for me was to throw too many crashes and too many bugs...
So... .riasusing posts and forums from all over the world, the largest percentage of the problem is given by net framework 3.5 libraries (with inside the previous ones!), no longer available on windows 8.x and in my case windows 10. then from an update of windows 7 of July made me the same joke. at the time I had solved simply re/installing the above libraries.
What do you think I can do? time passes and I'm losing work
just stay with windows 7.
my workstation at work I tried the installation of windows 10....nice and fast...but it does not recognize me the integrated network card, not even another I tried and not even two pens usb wifi. I returned to windows 7. is not yet mature to make everything work for those who have to produce without fail.
You're right. It's an hour and a half I'm following forums to solve the problem. I have modified registry keys, disinstalalto/reinstalled programs...nada de nada!
I had the same problem (gdtanalysissupport.dll loading error), and I solved it by entering the commands you said...
but, to better understand the problem, what does that command do? ?
go to start > accessories > button dx mouse "execute as administrator" on "prompt of commands" > fill the string as it is
if I did not find this comment I would never have solved... Thank you for sharing the information! ! !
