problem step threads
  • Thread starter Thread starter $davide$
$davide$
creating new drawings from 3d models of the 2008 version in the table is always specified the apx of the filettura even if it is a big step.
if manually I remove the note of the step the server publishes me a pdf by relaying the note of the step.
If you know what setting to fall, let me know:
Thank you very much
Thank you very much
Hello, David,
first you need to see what standard you are using. It seems strange enough that if you leave the quota and take the step back automatically on the same quota.
if in the 3d model is made with the standard bends will always be reported m8x1,25 complete of step. if you change standard in the 3d model and use iso you will be presented m8. for how I remember it is not separated the m8 field from the value of the step, so if you edit the quota you have to delete everything and write m8. So it's impossible to take the step alone.
to not make the step appear you can edit the calloutformat.txt file as reported in the guide solidworks.
