problem stratigraphy muro
  • Thread starter Thread starter kamikaze
kamikaze
Good morning to all, I tried to read something inherent, but I did not find explanations that helped me a lot.
the problem is as follows:
I modeled a wall creating 3 different layers (external finishing, xlam panel, internal finishing), when I go to insert a fix (door or window), revit cuts me only a stratigraphy and not all, how can I solve?
Thank you so much for your help, as always.
ps: do you know where I can find families of doors or windows for continuous facades?
I managed to find the subtraction solid and widening it I managed to solve the problem...I would like to ask you another question though. How do I turn the isolation back to make the model more likely?
depends on how you want them to turn the layers over the lock.
However, if you keep three separate stratigraphies, I see it very difficult to solve, sincerely I have never tried to use separate stratigraphies. the fast way would be to combine stratigraphy with a "type" of wall and at that point act on the folds, finally on the reference planes within the family of "window".
