problem support plotter canon bj-w3000 with autocad 2010
  • Thread starter Thread starter cececece
cececece
Hello, everyone.
a friend burned the pc and bought a new one with autocad 2010 only that when I set up the plotter I had the bitter surprise that was not + supported by the canon. The plotter in question is a bj-w3000. reading a bit on the net I decided to try with the creation of a pdf and then a plotter print, it all works well but when vad or to print customized measures greater than the a0 iso it does not allow me to print it .
What solution can I adopt? ?
Please help me.
to understand, the new pc has windows 7, for which the canon has not produced driver for this plotter. you installed compatible drivers but can't let you print more than a0? do not have a possibility of customization of formats?
Thank you for your answer first.
Therefore the os is xp and the drivers of the plotter are there while missing the autocad drivers for the plotter (pc3) because the canon supports until the autocad 2006. then reading on the net I decided to try the solution of pdf and then print them sucessively with the plotter but if I go out of the ao as size does not allow me to do it even if apparently the pdf has the size I need ..
I have a 800 series hp plotter, even for my lack of support for autocad versions above 2006. but not for that I have printing problems for formats greater than a0.
Excuse me, can't you, like I do, set up custom formats, above the a0, within the drivers of the plotter? and eventually use those formats, without going to create pc3.
anyway the plotter stops printing at the end of the drawing. without "get out" excess white paper. you can also use a 10 m long paper format to print only a few cm of ink area.
mm
We assume that I with the cad are at 0 having to help my friend in installing the pc.
However I have installed the plotter and when I go to the autocad print if I select the canon it does not give me the function customize if I do not install the pc3 (in 2004 it is necessary to do so). I've been freaking out for 5 days:frown:
...however I installed the plotter and when I go to autocad printing if I select the canon does not give me the customization function if I do not install the pc3 (in 2004 it is necessary to do so)....
I told you to customize the formats in the drivers of the plotter non in autocad:
...sorry, you can't, as I do, set custom formats, above the a0, within the drivers of the plotter? and eventually use those formats, without going to create pc3.
anyway the plotter stops printing at the end of the drawing. without "tirar out" excess white paper..... .
install the pc3? the pc3 is created does not install it, do not need autocad support installations to create pc3.
Okay, but how do I customize the formats in the plotter drivers?
Thanks again for the patience:-)
