problem taglia with autocad map 3d 2010
  • Thread starter Thread starter JimCarrey
JimCarrey
Hello.
I have a problem with the command size: I am operating on a topographic map (I downloaded the sheet from internet) on autocad 201 map 3d; the sheet is a pretty heavy file and anyway it also takes areas that I don't care about, I want to cut everything I don't care but when to make the selection window of the items to cut it tells me: the geographical entity was extracted as a geospatial entity. one or more geographical entities containing multiple parts or z values are being modified, geographical entities with multiple parts or z values are being extracted as geospatial entities.
I absolutely need a solution, I have to finish the project by Sunday!
Thank you in advance.
steak
Your information is lacunose. first: what format is the sheet downloaded from the web; second: how you entered it in map; third: what command you use exactly to "cut"
true, once you enter as a block use _xclip to hide the part you don't need
ps: all the block remains in the file so the heaviness does not change
I managed to solve the problem of cutting, but the file is very heavy and I have no idea how to lighten it. . .
have you also tried to delimite the area of interest with a rectangle and delete all entities outside the rectangle and cut one for all those protruding?
