problem types lines
angelo1389
Hello, everyone.
I am an engineer and work in a plant design company. daily use autocad lt 2016. I have a problem lately with the definition of lines types. I better explain the problem and ask you for help to solve it (maybe someone has already happened):
opening a known file that some lines (eg zig-zag or binary) are displayed as dots. Trying to reload the type of lines appears to me an error message of the line definition file (acadltiso.lin).
replacing the file in the directory with a non-corrupt taken by another pc the problem does not solve.
the problem also occurs, after opening the file "corrupt", also to all new files or files opened with that pc.
I hope I was exhaustive and there's someone who can help me.
thanks in advance to all.
Angel
try to delete all lines that give you the problem, execute the purge command and selectively delete the line type then reload the line type.
Maybe not to lose the lines that will then have to be associated with the new type put them on a dedicated layer, you will be easier to recover them all safely without including other unwanted ones.
in practice you have to clean the drawing from every track that leads back to the corrupt line type.
the thing also happens with the blocks, or the text/quota/director styles in the sense that until in the drawing there are traces of what you have to correct these corrections have no effect.
I mean any trace, not necessarily visible.
cuix, this file should be copied to safe zone to solve problems like yours.
you can try replacing with another pc as long as the autocad versions are the same.
