problem with assieme
  • Thread starter Thread starter Liuk_17
Liuk_17
Good morning.
I've got a problem inserting dense wheels into a set.
I took the wheels dentate from the toolbox, then changed them according to my need and finally I saved them by renamed them.
when I create the set and I call it no problem, but once the toothed wheels are closed and reopened, they no longer present the changes I have made but appear as a toolbox.
Is there any function I need to turn on or off?
It is normal that it is so that the toolboxes do not change but are configured. There is a command to launch to the file to remove the toolbox but I don't remember if the "no toolbox" is standard or something that had been built years ago in the company. first save the file in step or parasolid. You can also save it by name, in the configuration list add a configuration that is called default or whatever, delete the others and save. However they could eliminate gears from the toolbox because they are unmanageable.
to undelete the file from the toolbox the command is sldsetdocprop.exe present in the installation folder of solidwprks
