problem with bookcases and invent styles
  • Thread starter Thread starter djdanny
djdanny
Hello, guys, I'm freaking out! For everything I make inventor, I'm getting this mistake back.
How can I solve this?
the definitions of styles in the model c:\.......... below are different from the definitions of the style library; the definitions of the style library will be used.
layer: axis of work (iso) axis line (iso) axis line fold (iso) etc....
if for the new document you need to use the style definitions in the style library, update the model with new definitions. <se for the new dpcument you need to use the style definitions in the model, remove the styles from the library through library management styles
thanks in advance
if for the new document you need to use the style definitions in the style library, update the model with new definitions. <se for the new dpcument you need to use the style definitions in the model, remove the styles from the library through library management stylesthanks in advance
This message comes out when the styles are not aligned, likely you will have to open the idw template (usually on server) and you will see that it is not aligned with the styles you have (or have) modified.
open the template, update, wash and pass fear.
then copy the updated template even on c
