problem with colors in drawing environment
  • Thread starter Thread starter Stinox
Stinox
Good morning, in the company we had to do a refurbishment of the server, having changed the paths where I create 2 goes to fish the various templates, I had to change the paths in the config.pro. of course in the config.pro I set the new path of syscol and everything seemed to work egregiously at least for .prt and .asm. the problem arises when I go to create the table .drw. I create another color system. but the most unusual thing is that if you then open the table, if I manually open from configuration options the syscol works all correctly. Is anyone caught up in such a problem, or would you give me an explanation?
Hello stinox,
I didn't happen to have a similar problem, but it would seem that the program detects different configuration.... so to the eye I could assume that:
- at the start of the program for some reason does not hook the path to the syscol.scl file that you set in the config with the parameter "system_colors_file", usually the problem could be for some character that does not digest, or perhaps for the presence of the spazzi in the path... the creo may badly digest them or because it is simply written wrong, but hooks another syscol that has the colors prt and asm you want but not the drw.
to verify this try to do this simple test: delete or comment the line of the system_colors_file" in the config.pro and restart the program, the program in prt and asm still has the colors you expect? If yes, then it is present as supposed another similar syscol that is deceiving us. If not, I don't know what else to suggest. . .
what I wrote can be trivial but at a distance is the best I can suggest.
Good evening.
