problem with command ventola
  • Thread starter Thread starter davide33
davide33
hi to all I wanted to realize a fan with a sheet, the command for if it works but it does not allow me to give a height to the ribs higher than the thickness of the sheet because the field in which I should do it appears not selectable as soon as I give the outline of the sheet
Does anyone know how to solve this? Thank you.
If no one has answered you yet, it is surely because you are too vague, not from sufficient elements, you do not even say if the fan realizes it on the sheet, or if the ribs pieghi on the incudine!
if no one has answered you, it is surely because you are too vague, not from the sufficient elements, You don't even say if the fan makes it on the sheet, or if you ribb it on the nightmare!
considering that he asks for clarification on a specific command of a software I would say that his physical realization is unimportant, with you believe?
Of course, in fact the incudine is as a provocation to start a discussion, but it is excluded from itself.
but you, who are better than me in this field, why don't you answer them by giving them suggestions?
I didn't understand that.
If I still used solidworks I would try to help as I have already done hundreds of times in the past.
at least you don't know the "fan" command of solidworks you have no way of understanding whether the demand is short or not
the problem is simple if you leave from a sheet you can't change the thickness of the sheet, do the same fan starting from a simple extrusion (as if it were plastic) in this case it makes you vary all the size. If you want the sheet metal fan with different heights then you must use the forming tools.
