problem with coordinate file
  • Thread starter Thread starter Xythras
Xythras
hi to all, I am performing tutorials on designmodeler, in one of these you have to realize a revolution using as a profile a defined curve through a file that defines the points. the file is the following
Code:
10 0 0
1 2 15 93,17485624 0
1 3 30 180 0
1 4 45 254,5584412 0
1 5 60 311,7691454 0
1 6 75 347.7332975 0
17 90 360 0
1 8 105 347.7332975 0
1 9 120 311,7691454 0
1 10 135 254,5584412 0
11 150 180 0
1 12 165 93,17485624 0
1 13 180 4,41053e-14 0.
1, 14, 195 -93,17485624 0
1 15 210 - 1880 0
1 16 225 -254,5584412 0
17 240 -311,7691454 0
18 255 -347,7332975 0
1 19 270 -360 0
1 20 285 - 347,7332975 0
1 21 300 -311,7691454 0
1 22 315 - 254,5584412 0
1 23 330 - 1880 0
1 24 345 -93,17485624 0
1 25 360 -8,82107e-14 0
Unfortunately when I go to open it appears a read error immediately, if I generate the curve and visualize the warning tells me that there is a double coordinate to line 3, do you have ideas or suggestions on how to make the file work?
