dandee
I have a little problem that doesn't make me move on.
attached you will find the .ipt file on which I am working (it is in 2011, hope you can open it): I have to create a connection between two locations by using an "h" profile that I have developed with loft tool at the moment, but I can't continue with the extrusion to circular faces because the system extrudes me parallel to the plane, while I should make it hilly to the existing inclined extrusion. :36_1_5: I hope I have explained.
Maybe I'm making a mistake? Do you have any suggestions?
:36_6_1:
thanks for the help
:36_6_1:
thanks for the help
