problem with finetre architect
  • Thread starter Thread starter Lupox8
Lupox8
Hello everyone, I hope to be wrong but I have the impression that the doors and windows architect have not few limits of use. I list the macroscopic ones hoping that someone can suggest solutions:
1) taxes exist in one model and it is not possible to replace them with personal 3d panels as in the English version.
2) idem doors, you can some small customization of the panel but nothing more.
3) sliding doors cannot be represented open.
4)It is not possible to apply external frames to windows.
Overall I find the doors and windows of the English version much more customizable and I think it is a sin that has not been translated into English.
maximum
Hello, I am not able to give you an answer because I use the international version.
I hope some users of the Italian version can help you.
Actually, I thought the doors and windows were much more configurable.
I do.
maximum
Hello wolf8
I try to answer your questions, but you should attach some pictures of what you want to get
1) let us understand what kind of door you want to create
2) see above
3) the doors can be represented open, check thematic dialogues 3d of bar and frame of the architect doors set on slides
4) What kind of frames do you want to create?
Let's see if we can solve any problem
Zeno
hello, zeno,
Thanks for the answer. in order:
1) I do not want to create one in particular, it would be enough for me to have options compared to classical Persian. vertical slats for example. The point is that apart from changing the size of the frame and the inclination of the sticks does not seem to me to do anything else. Not to mention that the slats always drain from the frame making the side view not exactly outstanding.
2) idem with chips... place the panel setup window. How do I create a door with drafts? doors that incidentally happen very often to use.
3) Yes you are right but only in 3d. I did not see the same option in the 2d as instead in the swing doors.
4) I also have no special needs here. It would be enough for me to make a normal frame by defining thickness width and if I want it under the threshold or not.
The strange thing is that all this has already been solved in the English version. I don't understand why these parameters have been lost in Italian. I have seen that they are partially solved with the various special doors, however making the display in 2d always different as well as complicating the life in the general management of the design.
maximum
I strongly hope not to see solutions but I continue to find problems related to doors and windows architect.
how do I decide the opening degrees of external locks?
I don't understand. have given the possibility to dimensional the box of the coils and the dimensions of the sticks and do not allow me to decide the degrees of opening of the taxes. or I do not see the obvious or those who designed the architect windows have no idea how to draw and design a fixture.
