problem with grezzo
  • Thread starter Thread starter tester
tester
Hello friends, I have a little problem with the crudes, in the sense that if I make a project at home, then I bring it to work, you don't recognize them or you don't find them, do you mistaken something or do I have to set something in the options? Thank you.
You should just uncheck it
if you make a project on a pc and after moving on another all the paths of the rough and possibly of the milling area give you error because they do not find the right path.
you should just open the crude or milling area and re-elect it.
according to me you have to go to the setting and select template path and non project path
and the crude must be in the stock folder where you are working
thanks friends for the punctual answers, however I solved following the advice of arimal, because it seemed to me the easiest to do, thanks again to all.
