problem with il render
  • Thread starter Thread starter BlueEyes73
BlueEyes73
I have a problem with the rendering phase, I have attached a file to make the problem understand, in practice if with the configurations do different materials to a test cube everything works perfectly except the rendering that puts the materials as you like:frown:
If someone can explain why it's what, it's doing me a great favor:biggrin:
  • CUBO.zip
    CUBO.zip
with photoworks you mean?
and in the sense that it changed your color layout and just eliminated the blue one?
:confused: I don't know, I tried your file and the render is perfectly correct.. respected colors and everything ok.
I with swx 2009 sp 4.01 xp pro 32bit.
Mar
Mar
hi, sorry, the render I do it with photoworks and gives me the problem you see, in practice he put the colors as he seems not respecting those displayed, the images I attached are the preview to sx and the render to dx.
a fury to try I managed to do it correctly but I had to check "applicate only to the current configuration" for each inserted material. a bit palloso but I was convinced I was wrong before, but if you confirm that it works well with the attached file... :confused: bo...
ps... we are almost compaesani, province of cn also I :rolleyes:
strange, to me it works correctly with default settings with all configurations:confused:
:biggrin: I of worldvì,
And you? (if you can say.. Maybe I know your company, too. . )
Marco:smile:
So if you make the axieme make you equal to normal sight? ... umm... I just can't figure out why... No one else has time to try to see what he does? Thank you.
Marco:smile:
village san dalmazzo:finger:
