problem with levels and prospects
  • Thread starter Thread starter vergani.andrea85
vergani.andrea85
Good morning, everyone! !
I am new to the forum and would like to ask some questions about the use of revit 2013 with which I have recently worked.
I would like to ask you why at the opening of the file of a new project of revit do not appear to me the set levels of revit (i.e. the default ones of the program) and also the different prospects (those that on the guides call east-west-north and south)...!!! !
In short, I only have the possibility to see and choose in the project browser only the view in the plant and the view 3d?? ?
I can't understand where I have to intervene because unfortunately then I can't even insert new ones having only seen 3d and plant!!! !
I also tried to create objects with different heights and hope that the prospectuses would appear and instead nothing...wrong or is there wrong setting of the program? ? ?
Please help me. Thank you in advance! ! !
You are obviously not using any project template, probably because you have not installed the libraries. When did you install revit you connected to the internet? did you tell him what content to install?
p.s. I recommend you also have a nice corset, because given the questions I imagine you are very unpractical of revit
