problem with maschera.prt
  • Thread starter Thread starter effecci
effecci
Hi, I don't know what reason I start having a problem with my mask files today.
use creo 1.0
If I create a new test part.prt and choose as a mask for example mask.prt in the workbook I find the two test files.prt and test.drw.
if however I try to open test.drw tells me that mask.prt is not in the directory... or maintains the association to mask.prt and not to test.prt as happens when renamed without having the open drw. . .
until yesterday everything worked, today I opened the drw of the masks to make changes to the cartiglio and I can no longer come to the end of it.
Thank you all, I hope I've been clear.
I solved by deleting the start part directory and using instead of the last backup of recent days. Now everything works as before.
evidently after the changes made to the cartiglio and the next rescue something that I do not explain has created casino. . .
