problem
  • Thread starter Thread starter viper
viper
Hello, everyone, I have a little problem that never happened to me before.
during the table of a component, when I do the section do not appear the boundary lines of the section around the sampling!
I can't understand what the problem is, I also tried with the function displays edges etc etc, but nothing. I tried to make the table from scratch but the problem persists.
What could be? attached the espicative image (spero :-p)
thanks to all in advance
reverse section material removal and magically return to be visible.
if you have this problem you must also review the position of the views on the table.
in the image is the button next to the section removal, the double arrow.
hello trotto, thank you for your suggestion, but as I suspected you did not solve the problem!
Could it be some setting that has changed? I just can't get out of it!! !
bad luck is that I can't just post the file:-(
Anyway I tried and tried but nothing to do!
then I changed everything and I annexed the problem: I repeat that in all the other files that I have projects made in no one has ever happened to me this thing!!!
Please help me find the solution, I think it's a config or something... .
thanks in advance
upload this iso.dtl into design options and the problem will solve. in case you reverse the material removal direction.
I didn't understand why you used the surfaces to create the part. I would have drawn the profile and then made a solid revolution.
Hello, bitch.
thanks endless problem solved.
the reason why I created the object in question in that way is because I had to change the object completely for obvious reasons and why it was so built there is:wink:
question: why do you think only on this file has "sputted" something and not on all other files? but the drawing settings are not common to all files? is not a global settings? or are they related to the single file?
The design settings are global only when you create a new one, then always charge the standard, but you can change as you like from drawing to drawing.
yesterday I did everything in a hurry as I read the answer notification to the topic, so I came to check and since you posted the part I immediately thought to try with the iso.dtl that I use, that is good or bad identical to that base, I just varied something about the text, size of the arrows of quota and something else, so you have to put hand to these options to bring them as on your drawing.
Surely there's an option that causes you that problem, I didn't have a chance to verify what it is, why don't you do it with others I don't know if I don't see what it is first and if it depends on how it models the parts.
the program should upload the iso.dtl content to the $pro_directory\text\ directory, but you can always use one of your edits and save it to another directory.
if then someone really experienced can answer you more accurately well come. :smile:
