problema Angle override
jim78b
I have this problem:
if I make line then <45 to make an inclined line of 45° tells me angle override and this cpaita with all corners.
There is also an error signal... What do I have to do to make it happen?
I think you just have to give him the right syntax.
if you use <45 after the command line, you will see to move the axes temporarily 45° (angle override). and this always.
if you want to make a long line x at 45°, then the sequence will be:
line -> from point -> to point @x<45
It seemed abnormal to me that every time I did <45° it made the sound of error but if it is normal ok.
