problema apertura file con thinkdesign 2006
  • Thread starter Thread starter Nigol
Nigol
use thinkdesign 2006 with windows7 and I found the following problem:
I can't in April the files located on the hard drive (open window crashes) while this does not happen if I open the files from usb key.
if instead I click on the e2/e3 file located on the hard drive the file opens in thinkdesign. Did someone have the same problem and solve it?
Thank you so much!
version 2006 .. is not compatible with view and w7 I recommend you update it to a version that supports these operating systems 2009.3 for example.
Anyway you can try to turn windows update .. maybe you want to ass
Matteo
