problema con materiale e spessore su tab builder solidworks.
  • Thread starter Thread starter Stunman
Stunman
Hello, everyone.
from about a couple of weeks I wonder if from the last update to the release 2019 sp.3 I am the only solidworks user to have difficulty with the custom property file created with the tab builder.
the standard process set: I had created in the distant 2011 2 custom property files through the tab builder, one for the parts and one for the assemblies.
in the properties of the material and thickness for the file intended for axiemi I put the connection string to the part. therefore in the design of the assembly the cartiglio read the values of the material and the thickness indicated in the part.
from the last update the simple opening of the assemblies loses this connection. Therefore the question is whether I am the only one on the globe to have found this problem and in case negative I would really like to know how the other forms of life even remote that have impacted with this problem have overcome the difficulty.
I thank all those who generously want to contribute and respond.
