problema export 3d
  • Thread starter Thread starter Fabius3D
Fabius3D
Good morning. use solidworks 2017. I try to save a part in 3d file but it doesn't save me the file. says "in processing" but then does not process! Do you have any idea what this might be? Thank you.
side files are 3d files with sldprt extension.
if from the more precise infections you can reason above
Sorry.
I try to save a .sldprt or .sldasm file in .drive3d but it does not save me the file. says "in processing" but then does not process!
there are already discussions about the fact that you opened yourself
....I solved but I didn't find a solution... now I can make the move!
thanks the same
Now I try to search for a forum that deals with driveworks and its peculiarities. . I see if there's something here first:)
