problema finestra in archicad
  • Thread starter Thread starter Stefano 93
Stefano 93
Hello everyone!
I signed up right now, because I have a problem with archicad and I can't solve it.
the problem arises from the fact that I can't create a certain type of window, I attached it as an imagina made with paint:smile:
edit: nn I can do it with the inclined upper part of a chosen degree.
I hope you can help me, thank you in advance:wink:
yes, it should be tilted type of about ten degrees, now I do not remember exactly. :smile:
You have to build the window then. is simple with walls and floors, or recover the window of cumirko, in its library in the cd of archicad that allowed to change the geometry of the window changing a retino
actually only the floors are enough. you have to design the window with the floors (different the materials of course). then in 3d put the view as if it were in the plant and save the 3d as if it was a library object. and give him window settings
I don't know how to be clearer than that. .
drawings to the window with the floors, making the frame and the glasses, of course you need at least 2 floors to differentiate the thicknesses, then you have to decide how much to complicate the design to get realism.
then go in 3d, with parallel views and orbit the view so as to see the window in the plant, that is from above. do 3d file/save as object. then indicate "window."
This way you will have a window object ready to use
Yes, but the loft above (which constitutes the upper part of the window) does not rise to rotate it. .
the upper part of the window, the one that must be parallel, nn reescro to rotate it then in the 3d window...
cmq I think I have solved in another way...:smile:
thank you, however, I will make known;)
