problema importazione workspace su wildfire 3.0
  • Thread starter Thread starter Max_77
Max_77
Good morning to all, I write for an unusual problem.
on wildfire 3.0, I must import a .pws file sent to me by a customer.
the procedure I follow is: tools-----> server log-------> workspace ------> import workspace.
the problem is that as soon as I click on "register server" I appear in writing:" pdmlink server error not available at the moment. verify the connection or contact the administrator".
I do not have pdmlink, which in the import of a pws file, I know not to serve.
I haven't found anything on the web, so I'm addressing you on the forum hoping to find a solution.
Max.
I think you're trying to open files *.pvs not *.pws.
the pvs file can open it with a free viewer called now creo view express (ex productview) or directly from the cad even if I do not remember if in wf3 it was already feasible.
- - - updated - - - -ps: it is good norm before posting questions go to show up in the appropriate section.
the file is own pws, acronym of portable work space. you can not open it directly but it must be imported following the procedure that I synthesized in the previous post.
Any other suggestions?
p.s.
Hello.
test a (booked by online guide)
5. uncheck the set checkbox as main server (set as primary server) if you do not want to set the server as main.
Maybe you escaped and try to connect to the server you don't have!! !
Hello.
thanks the signal is pertinent, I think you try to connect to the pdmlink that I do not have. However I do not hide them that I did not find the check box indicated by the guide, I can choose "non-line server", option already active.... .
incorrect courier, I found the indicate box, it is actually sub-intested quini it is impossible to select it..... however among the various attempts made, I even deleted the server..... .
Does the workspace come from the same version of proe you use? I don't think of anything else.
..... maybe that's not the problem, during the import you have to check the item set as a server....., also you have to set the server as available in the offline mode. It should work.
It's all exactly as you say, but nothing... I can't understand. .
