problema quote
  • Thread starter Thread starter Alerm
Alerm
I've had a weird thing for a while and maybe I've never noticed before or never happened to me.
While I work on two drawings at the same time if I define the quotas on a plan of a drawing, then I move to the other I change the quotas also to this, and I return to the first I happen that some quotas are no longer changeable.
I try to erase the trait to recreate it but nothing when defined is no longer changeable with double click.
You think it's a software problem, or does it automatically make fixed odds for some reason?
Yet the fixed quota symbol does not appear to me! :confused:
is not editable or is it because you have instant 3d active and therefore the edit ae direct and does not open the pop up of classical modification?
no in fact does not even appear to me classical pop up that usually open with double click
only the menu on the left of the property if I click on the quota
But snapshot 3d isn't active
Perhaps they are of coccio, but from what you write you understand very little, practically nothing.
In the meantime, what does "signs" mean? in swx you have parts, assemblies, tables2d. So you work on what? two sketches on the same side? the ketch of the open-side file and the same of the part inserted in an axis? I don't think you're referring to Tables 2d, which incidentally would be more comparable to those you call "signs".
other thing: what is the fixed quota symbol? quotas are guide (black) or guided (grige). at least I don't know about it. fixed is a bond that you can put to the sketch entities (still symbol) or parts in the axieme.
if you cannot change it is because and a guided quota, that is the element you want to quote is already defined by the relationships with the surrounding ones.
post an image or explain yourself better, much better... and we probably come to the head.
You should put yourself in the shoes of those who read you. Try us and you will see that to interpret what you write you need the crystal peel:cool:
by drawings even if technically incorrect I meant sketches
by fixed quota symbol I intended to fix a stretch on a sketch, to win it, then once fixed the symbol appears in the sketch.
I have been very generic rightly I ask vey
cmq apparently I tried shortly ago to restart the program working on a sketch at a time and the problem does not arise
Are you sure that instant 3d is disabled and that it is not a guided quota as asked by "marcof"?
What version of solidworks did you install?
However, should you at least be able to change the value of the quota?
when you try to change the value of the quota you are changing sketch or do it with sketch "not changing"
also do the test by activating instant 3d and see if by clicking on the quota it changes the quota text directly. . .
Alerm
maybe satai working in creating parts and I think you work on two different sketches in the same function tree. when you interfer on a sketch you have to make it editable with the right button of the mause, change one at a time the sketches and exit and geometry rebuilds.
no instant 3d is disabled
It actually seems like it's a guided but it's not, and I noticed that if I try to change the value in the feature tree, it's editable.
but if I double-click the section does not appear the pop up change
the sw version is 2011
the cmq value I try to change it from sketch modification
I do the test by activating instant 3d
I seem to remember that sometimes it happened to me with the first releases of 2011. but then it seems to me they arrived at 2011 sp.5 and I no longer found those problems. . .
I assume if you have 2011 you will have the last sp?
no unfortunately sp3
Should I try to get my last sp maybe it's a software bug in this release?
Could be a bug, but aren't you in assistance? if you just log in to the solidworks website and download it from there. :confused:
Hey, guys.
I have found the same problem lately, that is, while I'm doing a sketch in one part, after two or three quotations, I can't change the quota anymore (the rotellina of the change disappears and the quota becomes as ultradefined). you do not change even if you double-click above the quota. I found a shortcut changing its value in the property manager of the share, but it is not a solution. Can someone explain why it's happening?
I have solidworks 2012 sp4 and the situation does not change either with instant 3d active and not.
Thank you very much
good morning.... sorry to someone happened that the odds are expressed in 0.02 instead of 20 and if you click on mmgs down to dx and then click on the odds these change in normal (20)... is only my problem and can you solve???? Thanks good work.. .
