problema sheet metal bend taper - mirror feature
  • Thread starter Thread starter terzi88
terzi88
Hey, guys.
I have a question to ask you, indeed two (maybe to someone has already happened and solved)
in sheet metal environment when I create a band taper you also create a line that seems to be associated with the feature but do not understand with what sense.
I can erase it but it automatically recreates itself.
in the info does not appear to be attached to anything, has no fathers or children....boh.. .
Is it just me? ?
second question,
Without leaving the line that is created, I move into work and create a mirror feature, is it normal that the band taper ends on the opposite side? ? . . .a normal mirror does not work like this.. .
I attach the simple file I have created to explain my doubts better...if anyone has happened and has succeeded in explaining how the mirror is thinking and what these lines are created....please share...I nn understand...:frown:
I'm sorry, but I don't know the sheet metal module.
I can only imagine that the line is a quote reference fold,
I'm throwing them, isn't it that there are virtual intersection options active in the view and that when you regenerate for a change the system you reactivate them?
the line actually seems to be the development of the sheet, if various the angle of the bander in fact you create a new line with the new angle set, at this point comes the beautiful xkè lines become two, the old in fact nn disappears.
I don't think it's a sight-related settling, the line is already visible from the modeling and I tried to turn off various spuns regarding the display or preferences of the sheetmetal but nothing... .
At this point both the creation of these lines and the method of reasoning of the mirror, I think they can be an error of the software...I would not exaggerate and for this reason kiedevo if to some of you the same thing happened...to understand in advance if it could be my mistake of operations or settings. .
So the line isn't associated with modeling?
Well, I'm better off hearing assistance.
if the gate and she recreates it would seem associative....but if I change it she creates another one and the first one gets released
nn so + ke dire...having confirmed by now seen the visits and no answer ke maybe only happen to me try to hear them.
thanks ip, good work! !
Bye-bye.
I'm waiting anxiously for the mach 3 with the sheet metal that I don't have at the moment, as soon as it comes I'll take a closer look.
I worked, however, as I think you too, with the 'old' sm. if you remember when you created a flange the edge was oriented in right and left. It's possible that this also happens in the mirror featues.
Remember that the mirror features is very different from the mirror body and it is not said that the 'logic' of operation is the same.
I remember that in the ug16 version if you had a hole passing on one side and mirrored the features the latter failed (that is, a hole in length ended). the reason was that the hole was 'to the face' (with an id) while the mirror face had another id.
I hope I've been clear.
in days the nx13300 should arrive and so I can give you more rascals.
Hello there.
