problemi con archicad
  • Thread starter Thread starter juli
juli
hi..scusate..sto making a project in archicad..it is a part of building....until the ground floor I managed because I opened directly the autocad plant with archicad and I drew over the walls etc. but now how do I make the first floor only with the polish of the ground floor??? ? I mean after I created plan 1 I need the plan plant but I don't know how to put it on archicad.......:confused:
vi allego il lavoro che devo fare....
pleaseeeeeeeeeee :frown:
I don't understand the problem. Can't you step up or can't put the dwg on the second floor?
I don't want to seem saviour to you, but in the second case, it's not enough to open the plant you need in another instance of archicad and copy it to the second floor of the first file? or put all dwg plants on a single layer and open that in archicad.. .
But maybe I didn't understand the problem.
no no no...then I did the ground floor. until here everything ok (the amount the plant on arches and drawing)....then I had to do the first floor: how do I????(I created another level of plan but I can not draw perkè the plant of the first floor is different from that of the ground floor)
with "I can't draw" you mean you try to make a wall but it doesn't come out, that you don't know where to put walls, or that something downstairs bothers you upstairs?
..I explain better....it's not that I can't draw walls etc. but I don't know how to use more than one plant i.e. one for the ground floor plus that of the first floor...to you it will look like a cabbage but I just started using it alone ..that is, it's me and my working companion...and we don't know how to do.... that is what you wrote here above ..the second option... ? ? Is that all? ? :biggrin:
you must ativate the reference sublucent (or ghost plane); in this way, when you move to the upper floor, you will see the lower floor plan, which will make you, precisely from reference.
