problemi vault
  • Thread starter Thread starter maior
maior
I have a problem with the vault. I've been using it for a while and sometimes I get this error when I go to save "a more up-to-date version of this file was saved by "me"
saving the file would result in overwriting the changes, which is an unallowed operation. If you want to save the changes, use save copy by name".
all this on a set from me extracted and modified......
and the thing makes me quite turn the boxes... how can I do not miss the changes?
alessandro
hi you are sure to withdraw to edit the files you need, or pe
Do you inconsistently pick them up?
I thank you first of all for the answer .. no no no the file is extracted as the axieme that contains it..in fact saves me the axieme (green ball with v) but does not save me the component.....
yesterday I solved so (but it is not possible to do it all the times :eek:) 1) I saved copy with other name;2) I cancelled the extraction of the original compon. 3) I cleaned the working air from the component;4 ) I posted "last version" of the component; 5) I extracted it; 6 ) I saved the copy overwrite the original component extracted.........but said among us......2 balls!! ! !
I really hope it doesn't happen to me... .
Hello and thank you again
As much as I can help you also happen to us ... but I did not mention that happens more often when I open a file from the project folder and not directly from the vault I modify it and then open the table or a set that contains it from the vault.
as a solution I try as much as possible to delete files from the folder at the time of storage and always open them from the vault even if I did not delete them.
