problemoneee with constraints
emanuele grasso
I can't bind two products between them.. tells me that the system is supervised but in reality it is not
I don't understand why you're bothering me
and no.. I also need the fourth bond
I'll explain. I have a base with a robot and a table on which it flows a piece
I fixed with the command "fix "
-basement
- fixed robot axis (base)
- Yes.
I put all the correct constraints between the axes of the robot and the tool (of course) I put it coincident with the center of the piece. .I don't understand why this coincidence doesn't put it to me while being in the full range of reachability of the robot
I solved. There was a boolean operation that gave me problems.. It made me go into an endless loop
another question: I used the "lock together" command to move more parts in the same untied together.. the problem is that if I move a component manually, I don't even move the others while having them stuck together.
If you try to move an object with the trepod, holding down the keyboard case, if you do not move in any way it means that it is blocked by the constraints...... is a proof that you can do x see if a product or part is sufficiently bound ........... .
Would that be the trepod?
using the analyze > degree(s) of freedom option will appear a component graphics with arrows indicating which degrees of freedom still exist
I indicated in the post before the photo.
You have to go to the menu.
I know there is no button
